mad force help BAD!
RE: mad force help BAD!
i have just remember that onec in the hobby shop the guy started his mad force and gave the full power and nothing happend i think that the gears snap becouse of something fell between them or the where loose. and did you read the review of the mad force in rc uinverse he said that he checked the engine mount and some screws so you must check all the screws before starting the engine.
MI
o i didnt check the screws, were can i find another 1st gear for the mad force, and do u no why the pipe was spraying out oil
my plane spray alot off oil the wings get dirty but you can tune it agian maybe you opend alot close on it alittle bit and you can find the three gears in towerhobbies it wont give you speed if its spraying alot of oil you must see some smoke coming out
#33
ok this is a link for all the parts for MAD FORCE RTR http://www2.towerhobbies.com/cgi-bin...I=KYOD01**&P=X
#34
MI
ok i got the gears on and the 3rd and 2nd gear slide on and the 1st gear screws on, is the only thing sapposed to be holdin these gears is the 1st gear cause thats the only thing thats holdin mine and im afraid to start it cause i think theres sapposed to be somthing else holdin these gears on, is there saposed to be or not
Zach
Zach
#39
Look in your manual ate the instructions how the 3-speed should be put together.
if you dont have a manual or if there isnt a manual with assembly pictures(i dont know because i have the kit) then you should get on or download it at madforce.net
#41
MI
i have the manual and i gess the gear just screws on but i just want to make sure cause i didnt think that 1 gear was saposed to hold all of them on i gess ill just locktite it
