spin out
I have been practacing at a local track so i can race.my maxx has a prob spinning out. not flipping.any one have any advice for me to keep from doing it.i need a soft suspension for the type of jumps but can't afford to spin out. help please!
YT, BOTSWANA
Ok, what kind of spinning out. When you are braking, or on the throttle?
What is the surface like?
What is your motor, and gearing?
Matt
Matt
ORIGINAL: freemaxx
it spins out during breaking into a shrp turn.it a hard packed surface not real high bite.i have a new OS 18 with pretty much stock gearing. i got this maxx for free so now i'm trying to get it straight. do you think i need some different shocks or a swaybar kit? thanks for the help Thermal!
YT, BOTSWANA
Ok, i gotcha. I love the maxx. I had alot of fun racing mine indoors. Run your front suspension a little stiffer than the rear. About 5-10wt heavier on the oil in front. No spring changes. Add a little camber to the rear, and some toe-in. No sway bar kit. You dont need it. Make sure your truck is nice and low too. Set the ride height so the front suspension arms are level, and the rear is slightly sagging. That should actually be achieved by doing the oil setup i mentioned earlier. Let us know how that works out for ya. Oh, and throw some Proline Bowties on there too.
Matt
Matt
ORIGINAL: freemaxx
cool thanx for the advice thermal.the track i run at is changing the track a lil this week. they are adding a few more feet to the straights.i'll make those changes and see how she runs. i did add some step pins to her but they don't do so well so i will try those boe ties. thanx alot!i'll let ya know soon.
