Please Help break in Picco .26
MA
Hey guys i need some advice on breaking in my picco .26 I ahve let 3 tanks idle through and putted around on the 4th. I had trouble with the carb though. Even at the most closed position it still got enough air into this hunkin big block to spool it up enough to start moving. Im not atlking a little bit either even on the most closed it sounded like it was wide open. But its not I looked so no need for the Is it open coments : p I wound up using the L tube from an air filter and taping teh end and puttin a pin hole in it so that it would get just enough air to idle. Problem being as soon as i try to open it up a bit it dies cause there isnt enough air. But if i remove the tape it runs way to high and i dont want to ruin the engine. No instructions with the engine as i tried to give in and read them but they werent there. Any help would be great..
