Urgent Hepl (pullstarter) ASAP
never has happened to me befor
i was starting up the savvy again the after a couple of pulls the pull start locked up..
so like any other person i took the pull starter off to investergate the problem
i unscrewed the little screw in side and the pull started retrackted back and in that split sec..
the coil sprang out at me..
anyway is there a chance of me stuffing all the coild back in
cause my LHS is the biggest rip off cause i live in AUSTRALIA
SO PLEASE HELP
SO PLEASE HELP
RE: Urgent Hepl (pullstarter) ASAP
Yes I do it all the tiime, I've never bought a replacement cause I fix them. Since its your first time its going to be tricky and frustratting. I've fixed it so much that I can fix it in 5 min but the first time it took me like an 1hr.
Anyway all you have to do is...uhh...this is hard to explain....thier is a website that shows you how to but I can't remember.
Ok I mabey this will help
http://www.hpiracing.com/walkthroughs/psrebuild1.htm
i have found a much bigger problem with the pull starter
the little disk that the string wraps around is demented the rope has started
to slice it in half but im going to fix it easy.
tomorrow ill be makin an aliminium i of the disk on the lathe so that problem will be fixed
