THE NEW HPI SAVAGE SS(pics)
My Feedback: (10)
Savage SS 4.6 features:
Nitro Star K4.6 Engine
High torque, 2.9 horsepower engine that is reliable, easy to maintain and easy to tune. Billet aluminum head provides high efficiency cooling, composite carburetor for consistent performance, pull starter equipped for easy starting.
High Performance Polished Tuned Pipe
Dual chamber design for higher top speed and wide power band.
Dirt Bonz Tires
40% lighter than the stock tires for more speed, soft and sticky S-compound rubber for high traction on dirt surfaces.
Dual Disc Brake
Stainless steel, drilled disc brakes provide serious stopping power, enough to do "brakies" on command.
Heavy Duty Diff Shafts and Cup Joints
Hardened for extra strength and to lengthen the time between re-builds.
Adjustable Upper Arms
Turnbuckles allow easy adjustability of the suspension geometry for improved handling and performance.
8 Spoke Wheel Satin Chrome
Realistic styling with a finish that looks like real aluminum, lightweight nylon construction for durability.
4-Gear Differentials
For increased drivetrain durability as well as extended time between maintenance.
Cam Type Servo Saver
Adjustable design allows precise tuning for optimal steering response and extra servo gear protection.
Heavy Duty 3 Shoe Clutch System
The 3 shoe clutch system paired with the massively “torquey” K4.6 engine gives you the power to do wheelies on command!
Optimized Gearing Ratios
With the 47Tooth Spur Gear and 17Tooth Clutch Bell, the Savage is geared for monster torque and wheelies on command!
Heavy Duty Dogbones
A powerful engine requires a heavy duty drivetrain for durability. We’ve got you covered with heavy duty dogbones, diff shafts and cup joints.
Front and Rear Skidplate Bumpers
Realistic skidplate bumpers made of high impact nylon look great and minimize crash damage.
2 Speed!
Adjustable 2 Speed Transmission with heavy duty metal internal gears for durability, bottom end punch and high top speed. Adjustable slipper clutch for drivetrain protection.
Nitro Star K4.6 engine features:
ABC Construction
The K4.6 engine features true ABC (Aluminum, Brass, & Chrome) construction — the ultimate in strength, durability, and high performance. The 8 port sleeve is made from durable chrome plated brass for strength and durability, and the lightened piston is made of lightweight aluminum for optimal performance. The knife-edged aluminum connecting rod is streamlined for performance and includes bushings on each end for added durability and strength.
8 Port Chrome Plated Brass Sleeve
Designed to operate at very high rpm's and crank out serious horse power!
Flushed Screw Settings for Fuel Mixture
The stock carburetor settings are made flush for convenient “back to factory settings.” This avoids unnecessary damage to the needle that other traditional carburetor designs can cause.
Hand Adjustable High Speed Needle
Conveniently tune your engine’s high speed needle by hand - no tools necessary! Tuning your engine just got easier.
Machined Head
Billet aluminum heat sink for better cooling and durability. Machined cut-outs for convenient access to mounting screws for easy disassembly.
Huge, 8.5mm Composite Carburetor
The composite material dissipates heat more efficiently than cast aluminum making your engine idle smoother and run more consistently throughout the whole rpm range.
Durable Finned Aluminum Crankcase
Cast aluminum crankcase is designed for maximum durability and heat dissipation with numerous heat sink fins.
Innovative Dual Stage Air Filter Design
The “High Flow” Dual Stage Air Filter dramatically reduces intake restriction as it smoothes and straightens air flow. More air means more usable power and acceleration throughout the engine’s rpm range. The innovative design also offers unprecedented protection from dirt and dust.
Standard Savage features:
Purple anodized, billet aluminum heatsink engine head
Adjustable upper arms with thick steel turnbuckles
Stiff shock springs
Pre-trimmed unpainted Nitro GT-1 truck body with pre-cut decals
Giant 1/8th scale (16.8" x 21")
44+ miles an hour!
Full-time shaft driven four wheel drive
Complete set of rubber sealed ball bearings
High performance aluminum dual chamber tuned pipe
Aluminum high flow tube rear exhaust header
Cast aluminum heavy-duty engine mount
Heavy-duty drivetrain and suspension optimized for big-block engines
Hardened metal differential gears
Heavy-duty chromed steel dogbones
Adjustable 2 speed transmission with heavy-duty metal internal gears
Adjustable disc brake
Wide-track suspension (nearly 17 inches wide!)
Stainless steel inboard hinge pins with anodized aluminum braces
8 long stroke oil-filled coilover shock absorbers
Rigid aluminum TVP chassis (Twin Vertical Plates)
Large 160cc fuel tank
Enclosed radio box for protection of electronics
Front and rear skidplate bumpers
Adjustable body posts (with an extra mount for SUV bodies)
* Compatible with T-Maxx bodies
* Compatible with T-Maxx wheels
* Compatible with T-Maxx tires
Also Available!
-- #87032 Reverse Module (using the 3rd channel of the radio system)
-- #87110 Roto Start System (will fit Nitro Star K4.6 engine)
#871 Savage SS 4.6 Kit with Nitro Star K4.6 Engine and Nitro GT-1 Truck Body
Suggest retail price: $779.00 (actual selling price will be lower)
man, i shoulda of waited, i just got the savage ss
RE: THE NEW HPI SAVAGE SS(pics)
Frozen, It's the only way they can still compete, I was just waiting for it to happen. Looks great though.
440 bux for it
for the lazy buggers: [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJUP1&P=7]Savage .28 SS[/link]
if id buy ot from, tower it would cost me approx. 513 euro =\ ill wait till it gets available in germany. They have good prices there.
My Feedback: (10)
dont expect hpi to update there website for a while, i mean the mt2 .18ss has been known about for a couple months now and theres nothing on hpis website
ORIGINAL: tamiyakid08
Oh well
My Feedback: (13)
Are you positive thats the same truck????
ORIGINAL: Tnx_4_life
440 bux for it
440 bux for it
Does anyone know if the SS bodies come pre-painted?
I know it looks sick and all with that body.
But is that something most of us won't be able to do? What with al those blue n silver flames etc?
it says(why cant u guys jsut read) it comes pre trimmed and deacals are pre cut. just add paint and stickers
Oh crap that sucks.
To get flames and stuff is too much work lol!
