Madforce Question
I have a twin force and I really like it so I am thinking about getting a madforce. The only problem Is that I hate nitro engines that require you to use a pull-starter. Does anyone know if either a shaft start system is available for the madforce of if the flywheel is accesible using a starter box?
Sullivan makes a tiger drive that will fit. The GX-21 starter shaft is 8mm, so just about any OS .21 starter system will be compatible.
The GX-21 in the RTR mad force uses model number S681.
http://www.sullivanproducts.com/Tige...fmainframe.htm
Here is a duratrax starter. #DTXP6020 should work.
http://www.duratrax.com/caraccys/dtxp6000.html
IMO, instead of nitro, go brushless on your twin. I did. I'll never own another nitro. :flamesuit:
Thanks for all the information. I was thinking about going brushless but a good brushless system is at least 300$ so I figure that for about 80$ more i can have 2 trucks. Plus you still don't get that much runtime with the brushless.
