large tires
FL
large tires
Hey, any of you guys know of a tire that will fit on standard tmaxx/mgt/savage wheel that is around 6.5"-7"tall. All I can find so far is the stock MGT tire. I know there has got to be somthing else out there that is that size. I understand the stock LST tire will fit on the tmaxx wheel too. Thanks in advance for the help!!!
FL
RE: large tires
Thanks...and they do fit on standard tmax wheels? Another memeber here mentioned they would, but the lst wheel is much wider than the tmaxx wheel. Not sure if the wider lst tire will be ok with the tmaxx wheel.
FL
RE: large tires
Here is what I have....an MGT with cnc machined 2.5" tmaxx wheels with 5/8" off set. I'm trying to get tires on them that are as big as the factory mgt tires. I like the 40 series wheels, but would like to hang on to the cnc wheels. Just looking for options other than the mgt stock tires. Tough to find a maxx compatible tire that is at least 6.5" in diameter. Thanks
FL
RE: large tires
I'm looking for the largest tires that will still fit on the standard tmaxx/savage/mgt wheel......I know the Kongs are 8.5", but they need thier own wheel...same story with the 7" hotbodies. I think the stock MGT tires are the biggest tires avaiable for the "industry standard" wheel.Don't care about the price.
