older truck... new problem (HELP!)
ok well i got an older my its a duratrax Thunder Quake 1/8 scale and the stock motor was originally tuned.. but when i got to get the motor check and sh*t they tuned it all back to stock (the needles for throttle and stuff) so now i start it up and it will idle fine and if i give it very very slight gass it will move fine.. but the second i have to either slow down (if i slow down it dies completely) and if i hit the gas fast it boggs down and almost dies and if i gas it long enough it will die.. and i think its runnign too rich but i'm not sure.. n e help would be nice
Jer~
Jer~
ON, CANADA
RE: older truck... new problem (HELP!)
on my thunder quake its still got the torq .21 that it came with , the factory settings are HSN 3 turns out LSN flush with the housing. Mine are set at HSN 2.5 turns out, LSN still flush with the housing and runs great. Hope that helps!
ON, CANADA
ORIGINAL: tidus10
umm this will make me sounds retarded, but what is. LSN and HSN??
ON, CANADA
ORIGINAL: tidus10
And where are these located?
tuning isnt a permanent thing.
RC Nitro engines are tuned on a knife edge to get peak performance. as such an engine will be sensitive to things such as ambiant pressure/temperature and humidity. So a truck that is fantasticly tuned today may not even start tomorrow.
go back to factory settings, start her up get her running nice and hot with about 5 mins of driving, and then lean her out in tiny increments, each time you lean the engine a little have a run up and down the road and see if there is an improvement, when you stop getting an improvement - stop leaning her out - however, if there isnt loads of smoke coming out the exhaust right through the throttle range(including WOT WideOpenThrottle) then you are too lean so richen up a bit.
HSN controls the mix of fuel and air going into the engine. the LSN does the same, but is effected by HSN changes (so if you lean/richen the HSN you automaticly lean/richen the LSN a little too, so if you change the HSN the LSN will also change - so set the HSN first, then the LSN after otherwise you will keep undoing whatever you do). The LSN only controls the amount of fuel entering the engine at tickover-about 1/4 throttle, so it is used to control the speed the the truck will launch and how it will behave at tickover - there are loads of systems for getting a perfect tune for both the HSN and the LSN - if you look through the threads you will find one. Frost keeps posting a pretty good one.
