Question About RB TM323
LA
I was wondering what percentage of nitro you'll run with the RB TM323? I have a T-maxx w/ the 2.5R and just upgraded to the RB and was wondering if the glow plugs from the 2.5r will work the RB TM 323? If not which plugs are best for the RB.
What kind of run time are you'll getting with the RB?
AZ
First off... I use 20% Blue Thunder... They say you have to shim the head if you use 30%, but I haven't run 30%.... the RB Concepts 1055TRX plugs are the ones I use... you can find 'em at www.acehardwarehobbies.com I've heard the 3232 plugs work... I've used MC-59's, but haven't had as good of luck with those as I have the RB plugs... and I usually get 7-10 minutes on a decent tune... (a little rich...)
FL
i run the same, 20% blue thunder, and rb plugz cant say about the run time because i dont let it go empty and im having to much fun to keep track of time
