Original Blackfoot & Frog question - quick
Just wanted to know if the Frog axles and drive-shafts are also interchangable? I assume they are since everything else back there is the same (I think). That is all, thanks!
Tim
Tim
PA
RE: Original Blackfoot & Frog question - quick
If you are asking whether the left and right dogbone can be switched around.... the answer is yes they are not side specific, at least not on my blackfoot.
Oh no, I meant are the axles/half shafts from the Frog interchangable with the Blackfoot and vice-versa? I'm pretty sure they are, just want to make sure the axles are the same size and that Frog axles would fit the Blackfoot....
Thanks!
Tim
Thanks!
Tim
