Savage SS K4.6 vs Savage X K4.6
IL
I have 2 extremely moded Savage SSs and was considering selling them off for the new Savage X 4.6 when it's released. The one thing that I dread is having to take apart the whole darn truck whenever I need to work on something, and from what I hear and have read the Savage X is easier to work on and get to whatever needs repair. Is there really a big difference in the ease and simplicity of the Savage X compared to the SS? Or should I just stick with the SS? Other pros and cons?
NC
RE: Savage SS K4.6 vs Savage X K4.6
The Savage X upgrade kit is $130 at Killer Hobbies. You will lose more than that selling those highly modified SS versions.
A better solution is to go with afermarket LCG chassis plates( or the HPI racer plates) and the HPI 25 style clear radio box cover. Then simply upgrade to the X style diff housings, transmission housing, and rollbar.
IL
Chronic, is the X lighter? I have the fast lane superduty tvps already. would the low cg tvps be as durable, if not more than stock tvps?
IL
Dude friggin sweet. Im doing the upgrade and found it for $119. heres the url;
http://www.philshobbyshop.com/tek9.a...fic=jnhmlrlqg8
NC
I haven't weighed one, but the X is supposed to weigh about the same as the LE did....10.5lbs. The only reason those weigh less than the base Savage is because they have lighter tires and wheels.
I would definitely follow Chronic's advice.. Numerous people seem to have been having problems with busted X chassis plates.. So why get them?.. IF(IF IF IF..) I even keep my X, I would almost definitely be looking at getting extended chassis plates from the get-go...
One other thing to mention - SOME others have also been having problems with the tranny case.. Not enough screws, flex, and thus busted gears, etc.. I can't say from experience - but I've read quite a bit about it.. I'm not saying it's definitely bad, but for me anyway, based on what I've read, there's a question mark..
