Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks
servo problem, come in, help me >
RC Monster Trucks Discuss rc monster trucks in this forum
Old 01-22-2003 | 03:47 PM
Default servo problem, come in, help me
the stock savage throttle servo is not working after i
tried to use it for the reverse module. i dont know what wrong
with it, it just stopped turnning.
i plugged it back to the throttle channel. it still didnt work when
i applied the throttle. but if i turn it clockwise a little, then apply
throttle, it will turn counter clockwise a little , then stops
responding.
my questions are:
is it broken?
do i need to do some " reset"?
thanks
Old 01-22-2003 | 04:10 PM
My Feedback: (16)
If you have another servo to try on that same connection in the receiver....that is one way to eliminate if that is a problem.
Otherwise....you should think about opening the servo and look for damaged gears....and if there are none....then it may just be failing/damaged and need to be replaced.
Good Luck!
Old 01-22-2003 | 05:01 PM
receiver is cool, gears are cool. i will take my radio system to
LHS, let those guys check it out
Old 01-23-2003 | 10:45 PM
Banned
My Feedback: (10)
the servo is shot go buy a hitec 645 servo 4 around $40.00 and a gas servo kimbrough saver (grey in color) that truck needs at least 100 oz torque. the hitec 645 has 130 oz.
