RC Monster Trucks Discuss rc monster trucks in this forum
does your pipe spit fuel
Old 01-23-2003, 09:41 PM
LandShark
Default does your pipe spit fuel
my savage pipe is spitting fuel on the vertical chassis.
is the HSN too rich?
thanks
Old 01-23-2003, 10:21 PM
Bluehydro8
Actually, all savages do that, it just depends how much oil is getting on your truck. My savage did the same while in break-in and a little after that. If the oil on your rig bothers you, try getting a deverter, this will channel all exhaust away from your truck, just make sure it is not longer than 4 inches otherwise you will feel a less-power difference
Old 01-23-2003, 10:23 PM
delcampo
My savage was also doing this alot. Once I started leaning out the HSN I don't have as much. LandShark have you started leaning out already?
Old 01-24-2003, 01:42 AM
LandShark
i did lean it, it is not spitting as much as before, but still
rcfireman
My Savage spits fuel out like it is foaming at the mouth!!!!!!! Actually this is just because it is to rich. As I lean it out I have noticed that there is less and less fuel being spit on the chassis plates.
Keep in mind that you want some fuel being spit out as this will show that you have lubrication for the top end. you should always see a stream of smoke coming from your exhaust while driving. No smoke means that you are to lean and will soon burn up!
We have all seen this, you know the T-Maxx who goes up against the MIGHTY SAVAGE and is burned up under extreme pressure!!!!!!! It is just a case of the small block wanting to be like the big block!!!!!!
Later
Old 01-24-2003, 02:14 AM
LandShark
mighty savage, i like that name. the guy at LHS told me
that savages kicked all t-maxxs' asses at off road track.
rcfireman, now is thursday night, still no flag. have you
gotten the screws?
Old 01-24-2003, 02:27 AM
rcfireman
Yes I did get the screws. Thank you. Have you gone to the UPS web site and used the tracking number to locate it? never mind, I just went to UPS and tracked it down for you. It is in Richmond Cali. right now. It is scheduled for delivery tomorrow. Keep your eye open for the big brown van!!!!!!!!!!!
Old 01-24-2003, 02:59 AM
LandShark
cool, they often come to my house around 3 PM.
btw, i dont know the track number si i can track it ^^
thanks so much
