building a hump pack
SD
does anyone know how to build a hump pack? i have the cells connected together and i have the 2 wires hooked on there for charging purposes but, i don't know how to connect up the receiver wire..... basically i need to know where the red wire hooks up to on the battery cells and where the black wire hooks up to. also do you just solder it on to the battery or how do i go about attaching it? I know this thread, in theory, would be better off in the batteries and chargers section, but i posted it in there and after three days i don't have any sort of attempt at answering so I've given up hope with them.
thank you
thank you
WI
RE: building a hump pack
It should be pretty easy. Red is positive( I think) Black is negative(again not sure). Hook up the positive wire to the last patter in the group positive side and the negative wire to the first battery in the group negative side. Now I dont know anything about making my own batteries so I may be completly wrong. I did A quick search on google and found I was pretty much right. The link below has alot of good info.
[link=http://www.yourzagi.com]http://www.yourzagi.com[/link]
