New idea for spur gears testing will begin very shortly
Ok i got some 39, 37 tooth spur gear that are 1m module wich will allow me to use a ofna 3 piece off road buggy clutch into my TC....I just ordered 4 of them and will begin testing as soon as i get them....
This is going to be fairly easy...I am 90% sure that it will work...No mods to the FRAT casing will be required the 39 tooth will fit tight in there but its going to work...
For the spur gear hub I am going to fab My own and I plan to make alot of them if the results ever proove to be satisfying and sell the spur gears and hubs to anyone that might be interested in this.....
The hubs are going to be molded into the spur gear it self then the right size hole will be drill into the spur gear...
I'll keep u guys updated....
wizen2002
wizen2002
Right now almost all converted .21 terra crushers are having problems with there spur gear....BY converting it to 1 module not only are the teeth of the gear bigger than the .8 module that tamiya uses but it will alow us to switch to a standard 1m module clutch system wich can take more serious abuse than the .8 module or 32 pitch gears.......
