RC Monster Trucks Discuss rc monster trucks in this forum
converting...
Old 02-05-2007 | 10:11 AM
Default converting...
this is my battery on-road converted to an off road!!!
What else do I need?
Old 02-05-2007 | 10:21 AM
Default RE: converting...
DIRT! but seriously, what all have you done to it? obviously, you've put on bigger tires/wheels. did you do any re-gearing?
Old 02-05-2007 | 03:58 PM
hunter306's Avatar
Needs a wider wheel stance and some better shock travel if you really want to call it an off-road vehicle.
Get some wider A-Arms first, then look into some wheel wideners if you can... It'll be more stable over bumps/jumps.
I sure hope that isn't belt drive or you should cut your losses and go back to the on-road model
Old 02-05-2007 | 07:59 PM
Ken448's Avatar
ORIGINAL: drive.hard-go.pro
a better camera
And a right front (or left rear) wheel repair
Old 02-06-2007 | 09:02 AM
no I don't need to repair the wheel...
I didn't put the hex hubs yet so that's y it's not straight
Changing arms is a good idea but the I need dog bones and other suspension.... later on I will fix this....for now I just want to see how well this car will run...
