Ofna Force P8 Purple
This engine claims 2.3 HP and 40,000 RPMs. I'm wondering if anyone knows of this engine. Would it work for the Savage? I also notice a tube going from the back to the carb. Is it possible to do without that feature so the pull start will fit?
it doubt it....if there is a P8 without the tube going in the back you wont be able to put a pullstart..and the tube (fuel line) going to the back is called a expansion chamber,or boost...it helps accelaration...
