MGT brake problem
RI
Hello! I just wanted to know if anyone else here has had a problem with the screws backing out that hold the brake pads in place. Mine keep backing out. I am thinking about using shoe goo or ca glue, but i dont want the srcews to lock up before I properly adjust Them. are there any other ways to fix this...thanks!
CT
Never had that happen on 3 trucks.I would try a dab of ca on the end of the screws that is supposed to tighten up the treads on plastic parts.The shoe goo sounds like it might work just be easy and use a dab and remember not to get anything on the brake pads and discs.A little longer screw might be worth a try too it would get more bite deeper in.
