Mutant Maxx help
I am building a mutant maxx and am wondering if the chassis parts such as the center diff, gas tank, etc will work off of any 1/8th scale buggy? I know that you are suppose to use gs storm parts but I was going to buy a buggy with a .21 motor like an ofna or kyosho inferno and use the parts. Need help? What will work?
1st Welcome to the board!
unfortunately Hardcore has had many problems with the Mutant Maxx and all they do is deny that there is any problem.
The GS Storm center diff spur gear is too small and you cant get a clutchbell small enough to make it work. If the kit is new return it before you get into the real headaches. Get the JT hybrid chassis or a Monster Pirate and Proline Bulkheads for the Tmaxx suspension and build a hybrid that will work. If the kit is not new and you got it for a really good price then what you need is get the center from an Ofna Monster Pirate or Dominator (around $30. on ebay), the spurs on those centers have 65 and 62 teeth respectively this will allow you to use the clutchbells from 12t on up for however much speed you want, also you can get a 2 speed for the MP/Dom center if you want. These will not drop right in, you will need to re-drill the chassis to make it work. just for an example of what I am talking about the Storm center spur is 51t (I believe) and the smallest bell is 12t that will equal 49.43 mph with stock Maxx tires, now the MP spur 65t + bell 12t = 38.78 mph these are calculated at 35,000 rpm's.
Please post how it works out.
The GS Storm center diff spur gear is too small and you cant get a clutchbell small enough to make it work. If the kit is new return it before you get into the real headaches. Get the JT hybrid chassis or a Monster Pirate and Proline Bulkheads for the Tmaxx suspension and build a hybrid that will work. If the kit is not new and you got it for a really good price then what you need is get the center from an Ofna Monster Pirate or Dominator (around $30. on ebay), the spurs on those centers have 65 and 62 teeth respectively this will allow you to use the clutchbells from 12t on up for however much speed you want, also you can get a 2 speed for the MP/Dom center if you want. These will not drop right in, you will need to re-drill the chassis to make it work. just for an example of what I am talking about the Storm center spur is 51t (I believe) and the smallest bell is 12t that will equal 49.43 mph with stock Maxx tires, now the MP spur 65t + bell 12t = 38.78 mph these are calculated at 35,000 rpm's.Please post how it works out.
I have already bought the mutant chassis. I did not know that jt even existed to be honest. I just wanted a mutant. Anyone want to buy a brand new mutant maxx chassis?
since it will not match i will trade you a t-maxx 2.5 woth hardcore-front and rear skids plates and front diff case with gears front and rear shock towers.robinson racing steel 72 tooth spur gear, trinity hump pack traxxas center skid plate super brain 959 chardger pirahna 1700 cell battery pack, pro-line maxx mulchers paddles, and 2 sets of stock tires!! if interested please tell me
thank you!
thank you!
