I keep going through glow plugs
My Feedback: (34)
I go through glow plugs like crazy with my tnx 3.0. I will use one plug for a few runs, then when I go to start it up again nothing and when I check the plug it doesnt work. When I install a new plug it runs fine. The glow plug is a light brown like it should be so I dont think the tuning is causing this. Also, while on the subject, what glow plugs would you reccomend? I've been running os a3's and have run a #8 before so I dont have any other plugs to compare performance too.
FL
RE: I keep going through glow plugs
Usually that is caused by running too lean. I've had them go out from running out of fuel under throttle too. I use OS #8 glow plugs in mine.
My Feedback: (34)
ORIGINAL: Bria1
CA
ORIGINAL: CustomTamiyas4Life
I think I may have found the problem since it's not running too lean with a tank full of fuel but I have run out of fuel at throttle quite often. I'll try to avoid that from now on and see how it goes.
ORIGINAL: Bria1
The following is just my opinion - and it is just an opinion.
Normal wear on a plug should leave it looking gray and over time, fewer and fewer of the coils stop glowing. Discolored (brown) plugs show a too rich running condition as deposits are being left on the element. You want your plug to be shiny for as long as possible, then it should begin to turn gray. An overly lean condition will not only turn the element gray very fast, is usually distorts the coil, possibly even having it break off and cause damage. If someone burns out plugs from running out of fuel, then you are tuned to the point of getting the absolute most out of your engine. Many racers do this, but many of those also get there engines for free... Most people want to run slightly rich of that point.
ON, CANADA
I agree with rc truck racer. When I am tuning for performance, the glow plugs tend to go quicker.
The general rule is too lean=glow plug life shortened. I use OS 8 plugs on my savage 4.6 and tnx 3.0 with no problems.
Keep in mind most nitro vehicles suffer from some form of half tank lean, some more so than others. If you tune for max performance at full tank, it WILL be too lean by empty.
I think glow plugs last longer on a big block for me because they are more powerful and I tend to spend less time tuning for max horsepower and usually leave it too rich ...
I have about a gallon on the first plug I put in an Axial spec1, that includes break in. I bought a dozen of the Med. tower brand plugs from tower, because I was killing plugs like crazy in my last engine, from what I have learned, it was running way too lean, so yeah, I think you are probably running lean, and burning them out.
My Feedback: (34)
ORIGINAL: Missing Pieces
My Feedback: (34)
I'm defineatly not too lean because it never bogs and there's quite a bit of exhaust smoke. Seems like when I lean it a bit though, it bogs every once in a while.
My Feedback: (34)
Well here we go again. I ran a little over a tank in the morning and it ran great. I ran it later and about 5 mins into the run I had just let off the throttle after a full speed run and wat do ya know, it stalls. I go to fire it back up and the glow plug is bad. What gives? I think I'm running a bit rich but whenever I lean it it bogs.
My Feedback: (34)
Well, I just took the plug out and the end is silver, but the element is blown completely down into the plug, the element isn't white or black either, looks new. Is it possible i had a faulty plug?
what plugs are you using?, and what engine? I'm 2 gallons plus on my first plug, in my axial, I went through plugs like crazy on my tower .25 engine.
My Feedback: (34)
ORIGINAL: RCtruckRacer
What do you mean by the element being 'blown completely down into the plug"? Are the coils distorted?
My Feedback: (34)
ORIGINAL: snowbl!nd
Try a slightly cooler plug, something like an OS 8.
The coil is broken from the top and compressed down into the plug.
My Feedback: (34)
Guess I might as well get that stuff since I went to start it today and the engine completely seized, the rotostrart locked right up and I made sure it wasnt a rock stuck in the starter gears byt turning the flywheel and sure enough it didnt budge. Nitro really is getting to me[:'(]
