.40 pics
NJ
.40 pics
I think its an x factor with a new body, i want to get an x-factor, put the .247 in monster pirate and put a the same engne you have in my truck. If you left the stock gearing in, how much power does it have? it should be able to pull you down the street
.40 pics
this truck is a x-factor. ive done some custome groving on the tires to make them super soft. also this thing was made for the 4 stroke. with this engine in you can idle it up rock and curbs. the best part though is that it sounds like a mini harley. ive had the truck for about 3 months and have had alot of problems at first. global hobbie has been great to warrenty everything so far. now that the bugs are worked out of it it is an awsome truck. I built the roll cage to protect the carb on the 4 stroke. and since it does lots of rock climbing rolling over is a commen thing.
