RC Monster Trucks Discuss rc monster trucks in this forum
tnx problem
Old 09-07-2007 | 12:32 AM
yz426flier's Avatar
Default tnx problem
my friend has a tnx and the engine is revving way more than it should be for how much power is getting to the wheels. i tightend the slipper clutch but we couldnt get it started due to the starting system not being able to turn the engine over. also when you push it backwards when it is off it makes the turns the engine. any help on any of these problems would help alot.
thanks
domenic
Old 09-07-2007 | 02:55 AM
Dil's Avatar
Dil
Default RE: tnx problem
maybe your running too lean!!! when you push it backwards the engine does not turn,, (thats normal) its just the spur gear turning the clutch bell the engine does not actually turn since the clutch has not engaged!!!!!
Old 09-07-2007 | 05:59 AM
Check for a broken clutch spring and check the clutch shoes.
Old 09-07-2007 | 03:33 PM
SaVaGe MaN SS's Avatar
your clutch shoes prolly melted to the bell i had that happen once or your clutch pring snaped
Old 09-07-2007 | 03:55 PM
jatoracing33's Avatar
yea, clutch shoes are your problem most likely. when you plug the starting system in, try picking the truck up and see if the wheel turn. if so, then thats definitly your prob
Old 09-07-2007 | 08:43 PM
yz426flier's Avatar
it was his motor on his starting system. its bad.
