Check out my Duratrax Warhead. Got Pics
WA
I had my warhead (not Evo Warhead) for 2 months now since i bought, but only played with it twice. Ok well over the summer i've been working on it and it turned out that i did a pretty good job to it.
Well here was what i did:
- Changed my warhead gas tank to the EVO Tank. (In Pic)
- Put A Blitz 5-Cell 1600mAh NiMH Std Hump.
- Installed a Switch Harness w/Charge Cord J.
- Installed a Ernst Charge Receptacle Futaba J FM (In Pic)
- Put a Silicone Switch Cover. (In Pic)
- Duratrax failsafe unit installed. (In Pic)
- Did the steering mod. (In Pic)
- Sealed the engine.
- Installed longer fuel lines. (In Pic)
- Installed shock socks. (In Pic)
- Painted the rims black with white on Duratrax. (In Pic)
- Customized a skid plate and painted it blue. (In Pic)
- Customized the front body with mesh panel put in the grill section and the front windshield (the hole). (In Pic)
- Installed a Durbo body klip retainer. (In Pic)
- Since i had L.E.D lights laying around i installed 4 L.E.D lights up front (2 on each side) and 2 red L.E.D lights in the back (In Pic)
- Also I have the HPI Mounted Super Mudders Tire/Ringz Wheel Shiny Chrome (In Pic)
WA
RE: Check out my Duratrax Warhead. Got Pics
more pics. sry guys but my pictures where to large to upload and i didn't want to resize it and they where good quality pictures.
WA
Everyone has a problem with there super tiger engines and people are saying it overheats a lot and they tried sealing it up, but still overheats. On mine i sealed up the super tiger, but it still reaching 280 to 310 degrees.(man that hot) I mite get a new engine for it soon, but it's still running (thats because i only drove it twice since i bought it) and i'm going to try and put the nova cooling head on it and see if it will reduce the temperature at all.
My Feedback: (35)
Thats what everyone said about the TRX 3.3 that comes on the Revo 3.3. I have never had a problem from any of my 3.3's after I seald them. As a matter of fact I took mine apart before I ever even started my Revo and sealed it. I use Traxxas 33% Top fuel in it and I have never had the engine over heat. If I decide to go with the Warhead Evo I'll do the same with it.
Very Trick Truck...w/ all of your mods to let air in you should'nt overheat.. and remember the Duratrax mis- print-- this truck will run at 290- 300 deg. and after break in should stabilize a little lower.. unless mine is gittin' loose or sumethin'...ARE you gonna' run this or is it just a show truck? [:@] Later.... Mess
Wow, very nice work on the grill and windshield. How did you make all of those holes? The Warhead is a decent truck IMO, but the stock engine/tank/ electronics are trash....[:'(]
Banned
Here's my savage 25 race truck. It's got HPI Low Gravity TVP plates and FIN Low gravity Motor Plate
Purple RPM Arms Front and Back with -2 degree setup.
HPI brake upgrade (Twin Metal Plates and pads)
Futaba Digital System Magnum 2PL
XTM 24.7 Motor with Rotostart plate
8 Purple spring shocks
HPI Tune Pipe
GPM Front and Sway Bars
Proline Bow-Ties
Integy Air Filter with metal body
Hitec 645 High Torque Metal Gear for Steering and High Torque for Brake and Throttle.
HPI Tune Pipe
Proline Bow-Ties
CA
ORIGINAL: Crawl-N-Clod
Can anyone confirm the axle size on the Warhead Evo??? I'm thinking its the same on the Savage, and original Warhead "8mm" is this correct??
OR
Very nice WH! that's gotta be one of the nicest I've seen... I am curious though, is it just a show truck or what?
Nice truck either way
chunky can you help me out dude? I just got the failsafe and i dont know how to hook it up to my warhead! Could you tell me how to do it and dude your warhead is the s@#$! Where you get the covers for your springs they look cool? Need to know how you hook up those lights to man your car is bad a@#? Anyway when i open the receiver i see the battery plug and four channel hook ups but i dont know where to hook up the failsafe and how to set it up! Can i hook it up wrong because i hooked it up to channel 1 and the lights were blinking and so i turn the plug the other way and the green light stayed on which one is it? Lend me some of your expertise please?
OH
dude, he hasn't logged in for almost a year, and this thread hasn't had a post in over a year. what page did you find this thread on, 250?
