Help with Warhead EVO!!!!!!!!
GA
My Warhead EVO will rev up when I press the gas, but it will not move in either direction. I have looked it over but I dont see any broken parts... Anyone have any suggestions? Thanks
ON, CANADA
RE: Help with Warhead EVO!!!!!!!!
check you slipper clutch... tighten it a couple of turns and try it. if that does not work, then you're cluth itself inside the clutchbell is gone. forgot to ask you, does your spur gear move when your reving it? if it does then the clutch is fine and just try tightening the slipper clutch...
ON, CANADA
the slipper clutch is the attached to the tranny between the tranny and spur gear. to adjust it find the spur gear, you see the nut in fron of it? that's what you use to loosen or tighten it.... do you have the diagrams for the truck? if not, go here
http://www.warheadmt.com/
ON, CANADA
try tightening it all the way now.. and if this does not work then it probably means that your tranny is shot or perhaps your reverse module is not engaging properly. play with the forward/reverse lever on the radio. hope that works!
CT
like I said in the other forum it got to be the topshaft gears pin it breaks into three pieces inside of the transmission, if you replace it you should be good.
Josh
Josh
