to put an .18tz in a Mini MGT?
CO
I have looked at every header that is for 1/10 scale that I can find, and still nothing that looks like it will work. If I can't find a way to make an .18tz work in my truck, I'll get the .18cv-r instead. But if anyone figures out how, please let me know.
WA
RE: to put an .18tz in a Mini MGT?
This is rear exhaust.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHLV9&P=7
CA
The O.S. S10 exhaust manifold will fit in the Mini MGT for sure this is the one I just to put the O.S. .18TZ engine in my Mini MGT.
Hear is a link: http://www3.towerhobbies.com/cgi-bin...?&I=LXBFJ5&P=7
I just found this old post about what header to use on an OS 18tz on the MMGT. I read that you have (had) that engine on yours. I just purchased an O.S. 18TZ pull start for my MMGT. What did you do for a clutch bell/assembly? did you switch to one speed? If so what gearing? Did you use the stock spur gear?
TR
TR
