RC Monster Trucks Discuss rc monster trucks in this forum
Shift Problem
Old 04-10-2008 | 04:45 PM
Default Shift Problem
2 days a go my truck was shifting fine (MMGT)
now when it goes into second gear it just spins freely, the engine just revs,
first gear is fine and its not the slipper clutch. but when it goes into second it just revs
if i very very slowlyspeed up it will shift very roughly but if i apply any gas it will just spin.
the spur and pinion gears are fine, idk what the problem is any help will work
Old 04-10-2008 | 06:49 PM
burningpoo's Avatar
Default RE: Shift Problem
Is the clutch slipping? Do you see the gears moving after it shifts?
Old 04-10-2008 | 09:05 PM
i cant tell
it will shift if the tires are off the ground, i think it was the one way bearing. i cleaned it and ill try again tommorow
i took apart the hole tranny and everything is there, nothin missin or damaged
