Gots me a problem, I thinks it's the Clutch Shoes, but wants feedback.
AB, CANADA
Well this is what happens. I will be going say at 3/4 throttle but as soon as I go WOT, engine revs way up and I see no gain in speed, and it might even slow down abit if anything. It has been getting worse and worse, before it only did that for the last 1/10 of throttle, now it does it for the last 1/4 of throttle. The guy that was there with me thought that there might be somthing wrong with the transmission, I looked though the little holes a didn't see anything wrong. I thought I would ask here before I go searching. By the way it's a Savage X 4.6
Shawn
Shawn
RE: Gots me a problem, I thinks it's the Clutch Shoes, but wants feedback.
Check the slipper. Tighten the slipper nut and I bet it will work although the stock clutch shoes are crap. You need to uopgrade to aluminum shoes with 1.0mm springs.
