suggestions for new savage engine
well... i took my savage to the local bmx dirt jumps.... was doing great till i over shot the landing on the big table top (while still on the gas) and landed from ~11ft of air - upside down.. heat sink first
well... broke off and bent heat sink fins... ruptured gas tank, brok the mount that holds engine to truck, and broke the engine housing along the side from mount back to pull start.
looking for suggestions as to a possible upgrade. i hear people talking about .26's in the savage. is this worth doing, and how expensive and how difficult would that be? would i be better off just replacing the stock engine?
thanks in advance for your input.
Ouch!! Too bad you don't have it on video. You could share the carnage with the rest of us.
CHeck with Noah I think he runs the .26 in his savage and he says with the right clutch set up i think his runs at about 45 MPH. everyone rants about the .26 Engine. I can't wait for my stock .21 to die so i can upgrade to the 26. Well good luck with the upgrade. You got to love this hobby.
My Feedback: (67)
.26
The picco .26 is a very fine engine. Runs extremely strong, and has tons of torque. It will drop right in, but I would rec. you change clutch setup. I am running a three shoe clutch with alum. shoes and 16T bell housing. If you go this route, try to get the mugen three shoe flywheel, as the kyosho one is too thick. Also, don't run the stock clutch, you will burn it up quick. Make sure you have HD dogbones, and get the metal hub that the brake rides on. This is about it. The diff. in power is day and night. Even when I was running the engine extremely rich, I could tell it had more power...the stock savage goes anywhere from 32-35 mph. I know I am going at least 10mph faster then the stock. It hauls butt, plus still wheelies around 15 mph in high traction surface (like grass). You can run this engine rich, and still have gobs of power. The only other engine I would rec. is the Sirio .27...but it's expensive and don't know if the case size is the same as the picco. Hope this helps. If you do get an engine, make sure you protect the head some way, as the picco will flip the savage with ease. I was doing back flips off a small jump with ease.
thanks for the speedy replies.
noah, if u have any part #'s i'd greatly appreciate it, sincec i am still fairly new to the hobby, i'm still a little stymied by clutches etc. will update when i figure out what i do
thanks again
thanks again
TN
The picco .26 or the hyper 8 port would be your best choice. It all depends on what you do with your savage. I have the picco .26 and it is awesome.
I agree with noahb. I would like to see about the Siro .27, but they are offering it in three different models. The non pro or racer should not be that expensive. But I don't know any specs for that one.
NJ
I have been waiting for the picco .26 for a while now. my LHS has had them on order from 2 diffrent distributers and still no word on when they are comming in
need more power.
need more power.
My Feedback: (67)
picco
The sirio is going to be offered with 11 ports...this is the expensive one. The cheaper one I think is going to have like 4 ports (sport model). If the sirio was only about $50 more then the picco, I would have waited...but it being the price of two piccos, I just don't see it having that much more power. Heck, I can't even get the power planted right now...sometimes it's too much power as it wants to wheelie all the time. The sirio should be better top end...but the savage is almost uncontrollable right now on top end...this is with stock tires. I am sure with low profile on road tires, it would make a huge diff.
new engine in savage
First of all , I think that everyones gettin a little bit too worked up about getting a new engine in there savage. Not that its a bad idea, swapped mine in my savage as soon as I got it, but its just that you need to realize that any considerable increase in horsepower( .7 hp-) is going to be very noticable. The outlaw .26, the new sirio thats commin out, the force 25's and the hyper 8-ports are all gonna make the savage scream, so Id just go with the cheaper one really, unless anyone here has any first-hand complaints. I have the outlaw in mine and its very overpowered and hard to controll, leading to some broken parts and is in need of some beefing up ( heavy duty driveshafts all around )
I have a .26picco and lov it . I can be going aound 10-15 mph and punch it and it rips the front wheels off the ground. You do need a 3 shoe clutch perferably aluminum and a bigger clutch bell. But i always have to have the biggest and the best, i will have the 11 port sirio .27 in 2 weeks. SO i will keep you updated.
thanks for all the replies.. i'm guessing that the picco is gonna be the best bet for the price.. as far as 3pc cluthces... are there any rhat will bolt up no modifcations required?
also savagebeast mentioned the outlaw .26. who makes that?
thanks again
thanks again
thanks again
thanks again
TN
Re: new engine in savage
