Lost
Got the dominator Thursday, opened it up put the batteries in the truck and the transmitter and nothing happened. I get the lights to come on the transmitter but the truck will not do any thing. Does any one have any suggestions. Except the obvious, the batteries are new, all the connections are plugged in.
Thanks in advance
Thanks in advance
My Feedback: (10)
check the crystals first,make sure they match,then check all the conections,if it still doesnt work use a multi meter to see if the rec. is getting juice if not theres your prob!
wes
wes
WY
ya check the crystals is both your Transmiter and the Reciever!! If the numbers are the same, while your radio box is apart to check the Rx crystal, make sure all the wires are snugg and in the right spot, and last but not least if none of that solves the problem stick a voltmeter on the connection between the battery pack and the Reciever!! If none of this works take it back to where you got it, and see if they have any ideas, but the only things it could be is, the xtals dont match, the batteries are to low, the wires are crossed, or you have a defective system that needs replaced.
