Heeeeeelp! whit my tmaxx 2.5
TX
My t maxx is almost new (1/2 gal), I did perfectly the break in, and now it works well when is rich but if it shoot down, is very dificult to start it.
When I lean it a bit to run like my friends it hots a lot(290f), my t maxx is imposible to wheelies,
when I see the compresion whit the plug, is o.k., but if the plug is removed i has nothing of compression
how can know if i nead a new piston and slave?
how is the compression in your t- maxx?
please heeeeeelp.
please heeeeeelp.
With the glow plug removed you should not get any compression. Th glow plug seals up the compartment giving it it's needed compression.
Did you break in your T Maxx like the manual said? Are you adjusting both the HSN and the LSN? Just trying to get some more info, so we can help you out easier....
