after market racing clutch...are they ova rated?
well, i dont know if i can justify spending $60+ on a clutch system, as opposed to dynamite long life clutch shoes for $20. they are nice though, like the 4 and 5 shoe clutches do make a noticeable difference, you only need the racing clutches if you are actually racing.
TX
Completely off-topic here, but, "full throttle with balls to the walls" is an oxymoron. Balls to the walls refers to an old-fashioned governor, which used two ball-shaped weights that were slung out by centrifugal force when spinning to govern. Therefore, balls to the walls means to go as fast as the governor will let you; While, Full throttle means, just as you'd think, as fast as it can go, making that an oxymoronic statement.
