:Titanium???
Does anyone make a titanium upper chassis for a .21 hardcore kit. :stupid: The new era one does not fit according to the lady at new era.
She sounds right because the hardcore kit (i think) makes your truck 2 inches longer and new eras makes it 1 1/8 in. longer?
Any help?
I am also having trouble with my rossi .21 why does it keep burning glow plugs
i use a very cold plug? :confused
Any help?
As far as your engine troubles I might be able to help you.If your buring up plugs then you might be to rich.What % of nitro are you using?I read an article the other day that said you only need a "cold plug" if your using a nitro content above 25% and you should use a hotter plug for nitro content below 25%.
A little off topic but my truck was running like crap because I was using 30% nitro instead of my usual 20% and the switch to a colder plug worked!So If your using 20% you should use a hot plug.
WY
Your talking about the main chassis correct?? If so the only chassis that works with the hardcore kit is the chassis that comes in the kit!! And IMO the hard core is alot nicer then the NewEra, because of the length, I like my pipe to lay flat and strait, and like the header to do the same with out hitting the shock. Maybe Im way off on your question, but hey I tried
Does anyone make a titanium upper chassis for a .21 hardcore kit. The new era one does not fit according to the lady at new era.
Any help?
I mean upper like a roll cage, full upper chassis
Any help?
WY
A ROLL CAGE NOT CHASSIS CORRECT?? The tube things???? A roll cage not an upper chassis
Theres alot of ROLL CAGES out there, partail cages and full cages. I dont know if theres any made for the hard core kit its self but Im sure many will fit it. Good luck.....
Rollcage but, I can't remember there name and it only works on some of the .21 conversion kits!
Maybe it was RC Raven on Ebay? But, I am not 100% sure of that!
WY
Yea RCraven is the only one I know that makes .21 cages, in steel and titanium, but Im sure there are a few others on the market, Id think any partial cage would work, but you probably want a full cage huh?? LOL
