Hyper 21 8 Port Question
IS IT NORMAL FOR THIS ENGINE TO REALLY HARD TO PULL THE STARTER?EVEN WHEN THERE IS NO PLUG INSTALLED IT SEEMS LIKE IT IS REALLY TIGHT AT THE TOP OF THE HEAD. IT WILL RUN FOR 3 OR 4 MINUTES AND DIE OFF. I DID TWO TANKS STATICALLY BECAUSE IT DIES OFF IF I TOUCH THE TRIGGER AND THE GLOW PLUG KEEPS BLOWING, I USED 3 ALREADY AND I AM NOT EVEN DONE WITH MY THIRD TANK. ANYBODY HAVE ANY IDEA? I AM LOST NOT TO MENTION FRUSTRATED. I APPRECIATE ALL THE HELP.
THANKS!
THANKS!
NY
i have 2 8 ports they are hard in the beggining. did u follow the break in right. mt directions said run 3, 3 minutes tanks then let the engine kool dawn and then do it again.
ITCHYTRIGGER
From what I have read on this forum it's normal for that engine to be hard to pull! Also break-in is longer then what they tell you in the manual! It took almost a gallon to break-in my Force .25 but, now it runs great!
CORYHP,
YES I FOLLOWED THE ONLINE MANUAL WHICH SAYS TO DO EXACTLY LIKE YOU SAID. MANUAL THAT CAME WITH IT SAYS TO DRIVE IT AROUND GENTLY THAT I DID NOT DO.
Sounds like your running too rich?
A good running temp should be around 220-250 depending on the engine! Running too lean or too rich can cause you to burn up plugs! What % nitro are you running and what plug?
WY
Hes just breaking the engine in, and with those temps, he his pretty much right on the head. Just lean out the low speed a tad maybe 1/4 turn or so. Also what plugs are you running?
