RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   MGT-Removing Reverse (https://www.rcuniverse.com/forum/rc-monster-trucks-160/2458599-mgt-removing-reverse.html)
ICrashThings 12-22-2004 03:03 PM
If I were to remove the reverse in my MGT to make it a little lighter, What do I need to take out? And I think I need to buy something for it too?
Thanks.:)
dakamat 12-22-2004 03:21 PM
RE: MGT-Removing Reverse
Buy the FOC kit from team associated
tamiya08 12-22-2004 03:31 PM
heres the FOC you need
http://www2.towerhobbies.com/cgi-bin...?&I=LXFVB7&P=7
then you would take out
-gears
- shifting fork
- servo
ICrashThings 12-22-2004 04:08 PM
Oh ok, my lhs has it. Thank you! :D
dakamat 12-23-2004 03:04 PM
Just a little thing, when you'll install the FOC, don't panic if you're not able to close the transmission case tight, becaus on the manual they give with the FOC, when it's time to install the gear on the output shaft, the picture not indicate the proper way to install the gear over the pin. To the place of slide the gear from the left side thru the gear, you must slide it from teh right side of the shaft.
Maybe you don't understand right now but when you'll have the picture in front of you, you'll understand.
Excuse my english,. i'am french from Québec, Canada.
Good luck:D
