RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   Temperatures for Break-in... (https://www.rcuniverse.com/forum/rc-monster-trucks-160/2494436-temperatures-break.html)
Salty0790 01-02-2005 07:04 PM
i got the Savage RTR for x-mas. i havent broken it in yet because i didnt have time to go out and get nitro. but now i have it. i was wondering if it is ok to break it in in like high 30 degree weather? will this harm my truck or shorten engine life?
Salty0790 01-02-2005 08:14 PM
RE: Temperatures for Break-in...
c'mon, you guys. i really need to know this....
fastcrash 01-02-2005 09:44 PM
i would wait till you get a 4o+ deg day. but you want to aim for 200 to 220 on breakin. do not touch the needles to atain this temp. instead, use some aluminum foil and a sock over the cooling head to hamper the engines ability to disapate heat.
UKownsU 01-02-2005 09:46 PM
Leave your vehicle inside until you plan to break it in. Do you have a garage?
Salty0790 01-03-2005 03:11 PM
yeah, i have a garage. but there is no room for break-in. it is about 40 degrees now. is it ok do break it in now? do i NEED to put aluminum foil on the cool head?
co_alpine 01-03-2005 09:08 PM
40+ is ok, but make sure that your motor is at room temo before you start it up. then, during cool down and restarts on the breakin, leave it in the house (on a newspaper so you don;t make a mess). do you have a temp gun? make sure your getting it to the 200-220 range for the break in or your not breaking it in, just killing it.
tamiya08 01-03-2005 10:45 PM
for the savage, it says in the tuning book, for the engine to be breaking in, the engine must be at temps of 190.
Ybenjulkay2x 01-08-2005 03:19 PM
Also you can use hair dryer to heat up that engine first before starting it. It is good also to break-in the engine at 200-220 as i did on my savage and raptor, temp here are diff in N.Cal[8D]. so i don't need that hair dryer unless it is veryyyyyyyyyyyyyyyyy cold. So don't forget that aluminum foil also, you need it.....:D
