How much difference would it make?
If I were to remove the electric starter and make it forward only in regards to weight and speed? Would it make that big of a difference? I like to auto-start and reverse, but if it would boost performance significantly to remove them, I will do so in a heartbeat.
Nah it only removes some weight and negligible resistance. The feature is more worth having than removing.
However thats purely based on my SPECULATION. I have no experience with MTs, but thats what my mechanical intuition says :) ram |
POJack, which truck are you talking about? T-maxx, or Terra Crusher?
removing the elec starter wont help too much |
i'm talking about the t-maxx
comparing to the total weight of t-maxx, the weight of the starter motor is small.
of course, it will help the acceleration, but not visiblly. you can change to pull start after the ez starter breaks which i know it may break sooner or later |
Re: How much difference would it make?
Originally posted by POJack If I were to remove the electric starter and make it forward only in regards to weight and speed? Would it make that big of a difference? I like to auto-start and reverse, but if it would boost performance significantly to remove them, I will do so in a heartbeat. |
Thanks guys...I guess it's not worth the hassle.
| All times are GMT -8. The time now is 04:55 PM. |
