RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   Maximum mt (https://www.rcuniverse.com/forum/rc-monster-trucks-160/8881222-maximum-mt.html)
nitromandh 06-25-2009 07:53 PM
Maximum mt
Ok so this is weird. Sometimes when i run my truck the engine revs but the truck doesn't go anywhere. I've checked out every problem I can think of. The differencial is fine and so are the gears. I don't know what's wrong. I installed the 2 speed transmission and everything on that is working fine. Any suggestions?
nitromandh 06-26-2009 09:17 PM
RE: Maximum mt
Never mind I figured it out but I have another question. Whenever I run my truck off road with the stock engine and a tuned exhaust, it seems like it doesn't have enough power to get up and go. I don't want to replace the engine. Is there any way i can boost the power?
calvino 06-26-2009 09:44 PM
RE: Maximum mt
Try a new tuned pipe on the car. Most stock engines are real low on power so it can be hard to get them to have enough power to "get up and go. IF your in the more "risky" you can try very carefully smoothing the entrance ports of your sleeve to help give the engine a little more power (not much though, its more for fuel economy but i have found it will increase power a little). If your real low on cash, try dropping 1 or 2 teeth on the clutch bell to give it more off the line power vs the stock setup ;)
nitromandh 06-27-2009 08:51 PM
RE: Maximum mt
the truck already has the tuned pipe and the clutch bell can't be changed unless there is a site out there that makes custom ones for the 2 speed transmission for the maximum mt, st, and bx.
bigairlife 06-30-2009 12:37 PM
RE: Maximum mt
it sounds like ur clutch is worn. try replacing ur clutch shoes and springs. that should grab alot better when u put the power down. try to get the thickest springs you can and dynamite max life clutch shoes
nitromandh 06-30-2009 07:38 PM
RE: Maximum mt
Ok I'll try
