TT ducati fm1e steering mod
RE: TT ducati fm1e steering mod
This is what im using. Im getiing a bit of a wobble at high speeds, so Im not sure if I need to change to some thicker oil( Im using 30wt) or add another damper.................
http://2wheelhobbies.com/product_inf...c84144a04431e2
CA
im not refering to a damper,i want to replace that fuel tubing stuff with spring loaded servo horn and i want to know what parts are needed
CA
this is what im tailking about but without the damper and spring loaded on both sides,not just one as pictured,by the way ,is this how you mount your damper??
Its mounted up the same way. Some diffrences like my sevo is 90* off of yours. Kinda blurry, but the best angle i have to show how its mounted.
CA
773W: 30-wt, of pretty much any manufacturer, isn't thick enough for the TT damper. I start off with 500 CPS oil (equiv of about AE, Losi, or Trinity 40), and make sure the damper is bled properly, that is, when the shaft is fully compressed, it does no rebound out due to air lock.
Lito
Lito
Thanks, I do have it set up properly and bled right. I Kinda knew it was the thin oil's fault. Good thing I have alot of time to work it out during the winter!
Are there any big diffrences between the two systems?? Damper vs double spring mod??
CA
so is that the proper way of mounting the damper,remove the 2 pushrods and replace the left side with the damper??
ORIGINAL: slicrick
CA
The TT one-piece damper really is a version of a two-spring setup, but with shorter springs in one unit (one spring outside the shock body, the other spring under the piston inside the body). My TT-based bikes, as well as my FPM 4-stroke bike like the TT damper, while my KP Black Shadow likes to have a longer dual-spring rod on one side and a separate damper (old OFNA one from a touring car I had laying around from 1999) on the other side.
Lito
Lito
So Im guessing that one damper will be enough, once i get oil thickness corect? Sounds like you have quite the colection there, would love to see a couple of those bikes......
CA
Yes, one damper should be enough. And yeah, I got bit hard by RC bikes a few years back:
TTn Ducati
NF SF501n
2 x DRP electrics (FM1e-based)
KP07 Black Shadow
2 x Kyosho HORs
OTO T258
3 x RS Ricky Carmichaels
FPM R30FS Four Stroke
DRP World's Fastest Motorcycle
2 x Venom GPV-1
TTn Ducati
NF SF501n
KP07 Black Shadow
2 x Kyosho HORs
OTO T258
2 x Venom GPV-1
Wow, didI mention that i would like to see a couple of those bikes (prob not since I had to edit last post), but now i want to see them all. Put up some pics and it might help me pick my next bike.................
FL
I actually went back to the stock fuel tubing set-up after trying one steering damper on the left side. For the life of me it just didnt "feel" the same to me. I even tried 1000wt gear diff oil.
In the pic above with the home made spring set-up on the servo horn, I can see that he used what looks like an Ofna 1/8th offroad throttle linkage kit to get the springs, and slider piece on the horn. Shouldnt be any more than $10 for the kit, might have to give that a try.
I like the damper. Not sure why, not like i now the diffrences bettween all thats out there. Im gona stick with it for now and see how the thicker oil treats me, It is always possible to run with another damper, that would be like the double spring mod .
Can anyone tell if changing the rider, nylon vs lexan, will make a difference in how the bike handles?? Im sure the weight difrence matters some how.
I have the damper on the left side on mine with 40 weight oil and a homemade rod and spring on the right side.. I copied TT setup from a friend... It works so much better than a single shock and 100 times better than the rubber tubing.. The rubber tubing made the bike steer like it was jello... the single shock had too much rebound and not enough holding power.. with the dual setup, wherever I point it, it goes and holds the line well, even in ruts.. I've had a few too many endo's with the other setups... total cost less than $20... Also, if you haven't already, change out the front and rear tirer.. the stock ones are too hard.. the front has a point on it, for what purpose, I don't know, went with an Flm1 tire and the rear is off the TTD nitro... what a difference that made...
New tires were on my very first order for new hop ups , Ya, what a difrence that made. I change dthe rims to for no reason other then I liked the way they look. I noticed that when I switched them out , the stock tires werent glued to the rims!!?? I went a head and glued up my new ones, not sure if it was needed, but it felt like the right thing to do at the time....
CA
Okay, here are a few pics of my faves. I'm particularly proud of the Castle Creations ad...
Pic 1: DRP Red Carbon on the left and KP07 Black Shadow on the right
Pic 2: DRP Red on the track (my fave and primary race bike)
Pics 3 and 5: FPM R30FS O.S. .26 four-stroke bike
Pic 4: Castle Creations ad
That DRP looks awsome. Thats a great pic in the ad, I would be proud too. I have a Novak BL system in mine. Maybe I should send them a pic..............
Hi! about damper i used the tte but the oil is leaking and its not working well on my steering. it has two spring i put outside and the second is inside. any help pls?
appreciated .thank you.
Here is my TTE mod with the original spring and shock setup.. I used a bit heavier oil in this one.. I think somewhere close to 40-45wt, but have since switched to twin dampers and a digital servo with 2.4GHZ spektrum radio.. I wanted rock hard steering with no wobble and tight feel.... If you shock is leaking, check the O rings.. they are probably nicked or worn out... If leaking from the top, check the bladder isn't torn...
Glad that helped... I had alot of advice from my friends and people on the forums for those mods.. the second damper works even better and the digital servo will allow the bike to track better.. the analog servo's don't center very well...
