RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
.18 engine problem
Old 11-06-2010 | 03:35 PM
Default .18 engine problem
i have a nitro evader st with a .18 engine i havent run it in a while so i went to start it up and it ran for like 2secs and shut off. i checked all the idle screws and set them to factory settings, i started it again and it ran full throttle even with the throttle in the idle setting. so i pinched the line to shut it off. any ideas?
Old 11-06-2010 | 04:02 PM
MastaDizasta's Avatar
Default RE: .18 engine problem
Sounds very weird. Sounds like air is getting in around the carb.
If it was me, I would take the carb out. Clean it up with wd-40 and reseal it with this stuff. http://www.all-spec.com/products/81878.html
Old 11-13-2010 | 02:53 PM
ORIGINAL: Shockdriver
Sorry I can't help you as I don't know about these engines.
