Having trouble with my losi xxx-nt. PLEASE HELP
I recently bought a losi xxx-nt with a xtm .18 motor. Fixed all little stuff that needed to be fixed. Went and bought fuel and a new glow plug starter and glow plug. Put it all together and tried starting it and nothing. Has good compression is getting fuel just nothing. I need help please. Also I clean the pull start and one way bearing. And tried seeing it it was hydro locked. Thank.
PA
RE: Having trouble with my losi xxx-nt. PLEASE HELP
Did you check the needles and how many turns you have in them. Try and put the needles back to the original setting and see how that goes for ya. Also make sure your glow plug heater is fully charged or has a new battery in it allowing your glow plug to get hot enough.
MN
I would also look at cleaning out the carb. I take mine apart constantly just to make sure my engine doesnt lean out. I always find the high end needle to be clogged. I just have to take off the whole high speed needle assembly off the carburator, take the needle fully out clean it and blow out the assembly. Also when putting back together just remember factory setting is usually flush or 3 to 3 1/2 turns out
