RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Hyper 7 will not start when Hot
Old 12-03-2003 | 09:12 PM
Default Hyper 7 will not start when Hot
I have an Ofna MBX Pro with an 8 port Hyper 7 Sport. It runs great when I first start it. Starts within 5 seconds and it is dialed in to run at 230 degrees. But when I try to start it after a run it won't fire. It sounds bogged down but I have made sure it is not flooded. I tried to fire but when I give it even a little throttle it bogs. I changed the plug and the fuel lines. I am running 30% Nitro.
I have called a couple LHS and they have no clue. Any ideas would be graetly appreciated. Thank you.
Old 12-04-2003 | 10:10 AM
teamsquirreltail's Avatar
Default RE: Hyper 7 will not start when Hot
Do you have an air leak somewhere? Check the backplate. Make sure that is nice and tight. If it's not that, check the carb for air leaks.
Old 03-17-2012 | 04:22 PM
Banned
bump
