Official HPI MT2 Thread
ON, CANADA
RE: Official HPI MT2 Thread
ORIGINAL: arapoda
Is there an option to buy the O.S .18 CV-RX Pullstart Engine as either a slide carb or a rotary carb?
Obviously the T-15 is a rotary carb, but if I were to buy a slide-carb engine how do you go about setting that up so that the servo, and the servo arm will work with it?
CA
[quote]ORIGINAL: nacodeblue
cool thanks for the help..so u didnt get it running yet? Yesterday i put the 18t clutch bell and 47t spur..u think i will be ok or still too much low end?
[/qumadman187 Date 2/16/2007 3:03:09 AM
I got a question for anyone that has installed an O.S TZ-TX in their mt2. On the crank shaft (part that is out for the flywheel + clutch) there is a drive hub that is on with a propeller nut. I was wondering it i have to take the hub out to install the flywheel. Would it do any damage to the crankshaft bearing? Im guessing not becuase the 18ss engine i have now does not have it installed..BUT i can never be too sure and dont wanna take a risk on the new engine.
I just removed it, not sure what will happen to crank bearing but I couldnt mount the clutch and flywheel with it.
mad man i would put some more cable ties on that heatsink you dont wanna scratch that sexy heatsink!!!!!!!!!!!!!!!!!!!!!!!!!!
guys when u wrap zip ties around the head y dont u put fuel line on the zip tie and feed it around the the head ? it will stop the zip ties from melting and protect it a bit more
TX
the zip ties dont melt without the fuel line
ORIGINAL: stadium truck freak
My Feedback: (8)
NH
TX
i think all of the OS .18 size engines have big block sized carb inlets so they all use big block air filters
wher do u get them massive air filters u guys have. i have one on my eb4 but the bend pipe is toooooooooo big
guys i am bidding on a hpi rs4 on ebay i am buying it so i can covert it in 2 an mt2 can it be done all the things on it look the same except its 2 speed and is thiner and small wheels. has any one done it ?
NJ
i know a we talked about this before in this thread but it can be done but u have to get some new stuff.. most important of all you have to get a new chassis. the rs4 3 chassis doesnt have the bend in the front of the chassis which is important for offroad use, u also have to get completly new arms and c hubs knuckles and hexes.. too confusing but it can be done... how much u buying it for
CA
ORIGINAL: murawskiallen
hey madmad wen you get your mTZ2 up and running post a video
TX
hey i just spent the last few hours taking my truck apart cleaning parts and then putting it back together
ORIGINAL: crohbober
ugh just spent an hour half putting my front diffs to the back... my back hurts[]
NJ
lol i cleaned my truck while i was fiddling with the diffs.. the good thing is that now i know how to take apart everything by heart.. it was a little hard since i didnt have the manual but i dont need it anymore
ORIGINAL: bubbles31
thats what i got pull start and slide cab and slide carbs run alot better over all.here are some pix of how i did mine and the peace i used for the servo came with my mt2i hope this helps
ORIGINAL: arapoda
I wonder if you guys can help me.
There's two O.S .18 CV-RX engines listed on the following webpage. One says "short" in brackets, so I'm assuming the other one is a standard shaft? (Both part numbers are different). But when I click on the preview image on each engine, they both appear to have a short shaft, or is this just the same image used twice as a visual kind of reference?
http://www.jespares.com/catalog/adva...p?keywords=o.s
yeah it is a roller and needs an engine fuel tank and radio plate and radio gear . but i was gonna buy it and convert it to a mt2 for my brother to use as bashing is boring when you the only one who has a rc car within 10 miles of my house
