Official HPI MT2 Thread
GA
RE: Official HPI MT2 Thread
I tried blue loctite on my header before going to a rear exhaust engine and still had problems. The jam nut worked with out a problem. But if it works for you that is all that matters.
Thanks 46U for the reply. Seem like you are the only one who willing to help me out.
I've not run in the LRP 18 yet, i know it is silly for the coming question i wanna ask but i still must ask it. Do you guys think that i should buy another engine OS 18cv-rx for spare and future use? Just in case the LRP 18 give way in future.
GA
ORIGINAL: evo165
The LRP is a good engine but never hurts to have a spare. Being I race my buggy I have 5 engines for it and at least one spare for all my others.
GA
ORIGINAL: crohbober
hey guys whats a good servo
im thinking of replacing them because the stock ones suck
All depends on how much you are willing to spend. A really good servo is going to cost $70 to $125.
ON, CANADA
the hitec 645mg is a great steer servo cost you about 40 bucks......I use a JR HS for the throttle and it seems to work great so far which are also around the 40 dollar mark
GA
The 645mg is SLOW!!!!!!!!!!!!!!!!!!!!! If you ever run a good servo you will never go back but like I said a good one COST. This is the least I would run.
http://www2.towerhobbies.com/cgi-bin...?&I=LXMUS3&P=0
GA
For the money you cannot beat the OS 18 CV-R or RX. I all so recommend up grade the CB and CB bearing set up. If you have the RTR T15 you will all so need engine mounts.
ON, CANADA
I'll second that my 18ss screams with the OS.18cvrx engine.....46U Yes that servo is slower than the one you listed but I've never needed faster steering.....I am a basher with an occasional track night for practice...so the 645mg is all I need. I run it in my monster truck as well.....at any rate both servos are a huge improvement over stock....
GA
ORIGINAL: RCCanuck
IA
ORIGINAL: crohbober
http://www.nitrohouse.com/acces,_servos.htm
my 18ss + kit is brushless so I can't advise on the throttle/brake
OH
hey, does anybody know if i can fit the dynamite mach .26 on my mt2... i saw video on youtube http://www.youtube.com/watch?v=HPXsDtjIpI8 and it is awesome.... anyone know where i can get engine mounts for it? any help appreciated thanks paul
GA
ORIGINAL: pjt123x
http://www.neweramodels.com/item.cgi...d=&part_id=709
OH
ok, thanks for the help.... what engine do you have..... can you post link please thanks.. i might go that way instead of a big block
MN
k who thinks that its a bad idea for me to make a xl5 system work with my engine and make the truck a hybrid.[X(] i have it all worked out but i would like any comments on what to do and what not to do.
GA
ORIGINAL: pjt123x
http://www.osengines.com/reviews/osm...st-rcnitro.pdf
http://www2.towerhobbies.com/cgi-bin...?&I=LXHLV9&P=0
ON, CANADA
OH
thanks a lot for the help.... i have the rtr.. but i stripped the ring/pinion before i had 2/3 of a gal through it.... so i called hpi and they are sending me the hardened ones for free... what else do you think i would need to put the tz on mine... what muffler did you use...or did you need any adapters... thanks for the help paul
GA
ORIGINAL: pjt123x
