Official HPI MT2 Thread
RE: Official HPI MT2 Thread
HPI used to sell the kit for the MT2 but they stopped making it. You can just use a 2 speed setup from an RS4 EVO3. You need the clutchbell and trans setup.
My Feedback: (9)
OK
My son has gotten me into Nitro Trucks and I purchased the MT2 but I seem to be having problems. I went thru all the break in as the manual said and ran it for 2 tanks after that but the performance seem to fall. I broke it in with 33% that my son had and ran out of that and bought some 20%, do you think that could be it? Also, I have been trying to tune it for hours and did it by the book with 1mm gap in the carb and put the HS and LS needle back to factory and got the idle and all set perfect (I did this with the wheels in the air where they can spin freely) but as soon as I put it on the ground the motor stops and this also happens when I try to apply breaks. I have loosen the breaks up and that problem cleared but what about the breaks? The only thing I can think of is the slipper clutch is too tight and the bell clutches are messed up, what do you think?
I plan on getting the above mentioned 2 speed but want to find out what the current problem is instead of compounding the prolem.
Joe
Joe
Try opening the gap a teeny bit more in the carb.
sounds like when the brakes are applied its pushing the gap a tiny bit farther closed
Also use blue loctite on the threads to prevent the screw from backing out from the vibrations.
SC
hello topflite,
When adjusting the carb for an idle, I did what the book said to do for breaking in. When I set the truck on the block and started it, I adjusted the idle screw till the wheels were not moving or just starting to turn. I had tested my brakes before I started the truck by setting my servos to center then using the adjuster to set them to stop the truck just by pushing the truck across the floor without engine power. Then I proceeded with break-in proceedure.
Just something I did to my MT2.
Hey guys...I just picked up a MT2 used but the guy only ran 1 tank through it. I finished the break in process. Is it me or is the .18 motor sensitive to tuning. My savage 25 motor has a lot of play when it comes to tuning it (I finished the brak in on that motor as well). It seem anything more than 1 turn in of the HSN from stock setting, it boggs under WOT.
Also, the brakes on mine are AWEFUL lol. I adjusted the end stop on the linkage as far as it will go just before the brakes would start to drag, and they still stink lol. I THINK it's because whoever oiled the filter put too much on it and it dripped on the disc. It takes almost 50+ ft to come to a stop from nearly top speed.I changed the shock oil to 35 and they are much better than that junk oil it came with stock lol. It was like water.
I'm posting in here to ask what you guys use your MT2 for. I got it as a good deal in hopes to replace my Tmaxx 3.3 (lowered, rpm arms/skid plate, integy bulkheads and spur gearand set up for backyard racing...nothing serious). I also have a stock savage 25 for bashing and jumps. I'm not all that impressed with the MT2. During tuning i ran into a curb ata 45 deg angle with the front end going, what I thought was quite slow getting on the brakes, and the screw on the bottom going into the steering knuckle pulled out. That didn't sit well with me knowing if an impact like that was an issue, I wouldn't dare jump the truck. God forbid it lands any way other than flat on all 4 wheels LOL. It doesn't have much of a low end pick up (maybe it's my tuning) but again the Tmaxx can rip and somewhat hang with my buddies Revo and Slayer Pro. The MT2 seems it struggles a tad on grass with the smaller wheels. I may get the Tmaxx extended chassis, and if I do I feel the MT2 couldn't hold it's own against it...deeming it uselss to me and I would sell it.
I'm basically looking for opinions from memeber who posted in a 849 pg thread on ONE TRUCK LOL. Is this thing only a smooth dirt track type of truck with minimal jumps?? Motor is brand new so an upgrade wouldn't be in my future. The savage 25 motor would fit but I don't want to dump money into the diffs etc....to keep the MT2 or not to keep the MT2 is the question.
...sorry for long post
NY
The MT2 has trouble in the grass because of the low ride height as well as the way its geared.
The plastics on the MT2 are good but nor quite as durable as the savage line. Unfortunately there are no aftermarket arms available for the truck. Id suggest getting alloy knuckles and C hubs. They hold up much better but you still retain the flex of the plastic.
As for the brakes. If you look back some pages you'll see pictures of the throttle mod I did on mine. It helps the braking but you still need a higher torque servo then the stock one.
The suspension travel isnt that long so its going to bottom out on large jumps. It wont soak them up like a savage or a revo, but its not supposed to. Its a stadium truck not a monster truck. The truck handles pretty well on most tracks. If you are going to attempt large jumps though you have to try to land on a down slope or its going to bottom hard.
The stock diffs are not the best. If you can get the SS diffs youll do better.
Dusted of my MT2 and took it for a spin today. Some kids have made some good jumps at the back of the local park so I decided to test them out. Also took the dog to give her some exercise. She loves RC Cars and will chase them all day long if you let her. LOL. Ended the run on a bad note though. Something swamped the frequency I was on and the truck ranaway across the park flat out until it hit a tree. Busted the servo saver. Lucky I have a 2.4 radio on the way!
Anyway here are some pics.
ORIGINAL: KeithjV
Thanks for the reply. Everything you are saying Ihave come to realize lol. I wasnn't expecting it to be a basher, but a little more durable though. I'm actually selling it because for me there is no use for it. The low end (again compared to my savage 25 and 3.3 tmaxx) just isn't there. Once up to speed the MT2 scoots though.
I made/making the Tmaxx into my racer so the MT2 is leaving. Plus I don't need another money pit and another heap of parts laying around LOL. I didn't really know what to expect from this... ohh well live and learn.
Hey Guy's
Just wondering what bodies out there will fit the MT2? My stock body is pretty beat up and I'm looking for something other than another stock body to replace it with.
Cheers
Rusty
Cheers
Rusty
ORIGINAL: RustyTumbles
Hey Guy's
Cheers
Rusty
Hey Guy's
Cheers
Rusty
http://www3.towerhobbies.com/cgi-bin...?&I=LXTM59&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXAPU0&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXAPU1&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXAPU2&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXXD92&P=7
Just to link to a few that should mount on with 0 mods
ON, CANADA
If you throw in the trx 3.3 you would find a huge difference ,as for the parts i boiled mine first then assemble makes them bend more without snapping lol
ORIGINAL: smitty2919
Thanks for the reply. Everything you are saying I have come to realize lol. I wasnn't expecting it to be a basher, but a little more durable though. I'm actually selling it because for me there is no use for it. The low end (again compared to my savage 25 and 3.3 tmaxx) just isn't there. Once up to speed the MT2 scoots though.
ORIGINAL: KeithjV
Well I picked up a LRP .30 for my savage and I may throw my 25 from the savage into the Tmaxx....so I will be upping the power of both trucks... I could throw the used 3.3 from the Tmaxx into the MT2 but then I would have to upgrade the diffs etc....hence it becomes a money pit LOL.
I know once the bigger motor goes into the MT2, things will start breaking and I won't want to fix them. Thus making it harder to sell.
I would like to see how it moves with the TRX 3.3 though
ON, CANADA
You could check mine out on utube should be under mt2nitronut2 if i,m not mistaken dont get utube here at work so i cant get the link
ON, CANADA
Heres the link found my old post lol
http://www.youtube.com/watch?v=F9cUMegvpg4
ORIGINAL: mt2nitronut
ON, CANADA
Trx 3.3 simple motor mount spacers underneath origginal trx motor mount hold clutch bell to spur
gear and mark holes lol
