Wheel Question
yes they will although i have found the ae rims to be hard to get on and off. i always have to use a pair of needle nose plyers to get the ae wheeles off.
doubt it. RC10GT is such an old design and parts that only associated-made parts will fit on it...and some others but i doubt associated wheels will fit on the losi xxx-nt.
ORIGINAL: ericheller
its the same size axle, but i think you have to modify the wheel where the pin goes(with a dremel tool). its just as hard to get them off the ae, at least the wheels ive had because the walls slant and its really hard to get a hex driver around the nut.
Cool, thanks for the info, tho it might be useless now. I found that a set of black HPI 5-spoke wheels with adapters to fit nicely. The reason I was asking in the first place was because I was wanting some black rims.
Again, thanks for the info.
