glow plugs what should i use
RE: glow plugs what should i use
What nitro percentage are you using? People might say that a hot plug is better for the cold and a cold plug in the summer is better but they are wrong. The temp of a glow plug has nothing to do with the outside air temp. If your running 30%, I'd recommend a medium. If your running 20%, a medium to hot plug. For under 20%, a hot plug would be best.
ON, CANADA
I`m using 20% well was using sense there is alot of snow up here in the north havent had it out to cold. I`m also working on the rustler right now just doing some upgrades.Thanks for the help Andrew
I also run my truck in the cold up here in the north the os #8 works awesome with blue thunder 20% or any other 20% nitro content fuel
