RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
What is a Bump start???
Old 03-01-2004 | 11:13 AM
XXXNTFREAK's Avatar
Default What is a Bump start???
I was wondering what a bump start was, and could i use it on my XXXNT?
Old 03-01-2004 | 11:22 AM
Default RE: What is a Bump start???
a bump starter is the same as a starter box and yes you can use it on the xxx-nt
Old 03-01-2004 | 11:29 AM
XXXNTFREAK's Avatar
Alright, then whats a hand starter, not pull-start
Old 03-01-2004 | 11:36 AM
look at this site
http://www.rcnitro.com/rn/articles/system_basics2.asp
Old 03-01-2004 | 04:58 PM
ericheller's Avatar
bump start? thats in a real car when you have people push it and drop the clutch when your battery is dead.
Old 03-01-2004 | 05:27 PM
ICrashThings's Avatar
ORIGINAL: ericheller
what he said^
Old 03-01-2004 | 07:33 PM
Doesn't work with new model cars though....only the ones with carburators and no computers. Also DO NOT try it with an automatic car. I saw a video of some theives trying to do that and they smoked the tranny.
Old 03-01-2004 | 08:23 PM
Bush Wacker's Avatar
bump start? thats in a real car when you have people push it and drop the clutch when your battery is dead .
We did that with my Mom's RX7. But the battery wasnt dead.
You can do it with a new model car, as long as its a stick and you can turn the key over.
Old 03-01-2004 | 08:47 PM
i8tweety's Avatar
Bump start is when you use a starter wheel (either on a hand-held motor or in a starter box) to turn the flywheel on the engine.
Old 03-02-2004 | 03:30 PM
ericheller's Avatar
you can do it with any stick shift. with a automatic it wont work because there is a clutch that engadges. i did it on my quad when i was little, once in a while it would go dead. i tryed it on my 400ex and it has too much compression, the wheels just lock up.
Old 03-02-2004 | 03:52 PM
Frost_'s Avatar
In an automatic, the torque converter slips; ie. does not acheive lockup. Hey, on your 400ex, try it in a higher gear, if it locks and drags in 1st try 2nd, if it still does try 3rd, one of those will work for you... actually the same goes for a car...
Old 03-02-2004 | 04:16 PM
ericheller's Avatar
ORIGINAL: Frost_
ya i know i think i tryed 1-3rd gears, its hard to get it into higher gears when its not moving. it was cold and snowy at the time but i thought the studs would grab. it didnt matter anyways because i found out the plug was fouled. i dont like doing this. my dad was telling me about starting his truck along time ago by pulling it with his 3 wheeler(like i said along time ago). i guess my bro was in the truck and he had the key turned off so it took them a while to figure it out.
