Official Thunder Tiger DT10 thread
Ok i though i would start a thread for the Thunder tiger dt10 nitro stadium truck. Pictures of my thunder tiger dt10 are here on my website http://www.geocities.com/nitroandele...ndertiger.html if you got any problems or question feel free to post.
MD
RE: Official Thunder Tiger DT10 thread
u may want to adjust your front tires so they sit flat on the ground...unless u wanted them to run on there sides like that.
I've got one to...I mounted a OS 15 CV-R on mine...hanven't runt it much with that engine though...
I like the truck, it's the first R/C I got and I had some initial problem with it but since I monuted my home made "roll-cage" I haven't broken more than one front wheel...and that inludes some rather heavy impacts...
I've got loads of photos on my homepage : http://dclxvi.no-ip.info
Here is some samples :
hey guys i have a dt 10 great car but weak engine having problems with it since i bought it and
DCLXVI NICE i like what i did with ur car espessily the cover VERY COOL
i mutaned a 12 cvr o.s. on it voz i hated the TT 15
You mean the body? That is the Kyosho USA-1 GP (Nitro Crucher) body with the chrome parts...
I think the TT 15Pro is a great engine, holds the tune easily and average power...although, I changed the glow plug to a QuikFire F7 quite early...that one are soooooo much better...
hey again i was just wondering that my DT-10 doesnt do wheelies i have a 12 OS on very powerful its a power of 15 engine but it doesnt wheelie only if i hold it up on the back wheels and then i go and move my hands, it barely do it right, any ideas ?? thanks
I don't really know about the width...I've never seen an RC10GT in real life...but the body is this one : http://www2.towerhobbies.com/cgi-bin...?&I=LXT553&P=7
And you'll need atleast the first of the listed accesories...
^^_FaWaZ_^^: Gear it down or move more weight backwards...(mount the battery pack on the shock tower)...if you regear it (lesser teeth on the cluch bell) you'll loose some speed...I geard mine more for speed (17T instead of stock 15T) and it will almost lift the front end...I bought a revicer pack (6v 1100 mHA NiHM, five cells side by side) that I will try and mount beside the throttle servo, I hope that this will give the truck somewhat better weight distrubution as I think it is a bit forward shifted right now...
i have 2 (?)
1- i cant stop braking the bulkhead on jumps is there any alaminum parts ?
2- that truck is sooo hard to keep clean do i have to open all the parts every time i finish running and clean them?? [:@]
I had some problem breaking bulkheads aswell...I solved that by making the rollcage you can see on one of the pics above (my server is down at the moment, I forgot to restart it before I went to work this morning)...
I mount the body on the roll-cage...I had to extend the front pin somewhat but that is no biggie...and if you are running the stock body, you won't have to...
Thats funny, cause i never broke a bulk head on mine. So one needs to make some aluminum parts for the thunder tiger dt10, like a-arms, or new shock towers, etc.
I think that the A-arms are unbreakable...knock on wood...I have never broken one of mine and I have put it up to extensive abuse...
new tires
yep those A-arms are soooo coool they dont brake at all.
but now my tires r all worn out and i bought a new pare of tires but i have problems insearting them [&:]
i cutted down the old tires into pieces to take them out but theres still pieces of stuck rubber on the wheel how can i get them out ??
i heard that ice breaks the glue down so i putted them in the freezer for couple of hours but nothin happend so i need help now [X(]
RE: new tires
Try cooking them...worked for me...(it was still hard)...
Try cooking the whole tire and rim before you cut it next time and you can pull the tire off...
