Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
 RC10GT Pull start to Bump Start ?'s >
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 05-16-2004 | 11:39 PM
Default RC10GT Pull start to Bump Start ?'s
Hey guys, the blisters on my hands are the last straw, time to go bump start. I am getting a kickass ofna start box from ebay. I know i need a associated Flywheel and a OS cover for where the pull start once was...what else do i need? I really dont see the need for the different motor mounts, since the mounts stop short from the opening around the flywheel, unless the non pull start mounts are lower so the flywheel gets closer to hole? Also i cant imagine that the manifold would be a problem at all....Thanks for the help guys, my fingers appreciate it!
Old 05-17-2004 | 07:22 PM
GT-Power's Avatar
Default RE: RC10GT Pull start to Bump Start ?'s
the new mount makes your engine sit lower so it touches the startbox and also improves handling since it sits a good bit lower
Old 05-17-2004 | 10:46 PM
Frost_'s Avatar
Also, you don't need a cover. Just remove the pullstart carefully, tape it up so it will stay together in your parts box, and you are ready to go. The actual seal for the engine case is between that backplate and the crankcase, so there is nothing to cover/seal off.
