RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Priming problem
Old 05-30-2004 | 06:37 PM
Slacker's Avatar
Default Priming problem
I have a nitro Rustler with a Fantom .12 engine and just got a Team Associated low end tuned pipe for it, but I'm having problems getting the truck to prime (the finger-over-stinger method) and I have to disconnect the fuel line from the exhaust and blow in it to get the truck to prime, but that's a pain in the butt. What gives?
Old 05-30-2004 | 07:04 PM
jkdv8's Avatar
Default RE: Priming problem
Try replacing the fuel line with the clear kind so you can see it enter the carb. Then turn the engine over a couple more times. then try to start it. That's what i do to my maxx and it starts everytime.
Old 05-30-2004 | 07:45 PM
Slacker's Avatar
I already have clear blue fuel lines, so I can see through the lines to see the gas flowing. Also, the only way I can get the fuel from the tank to the carb is if I blow on the tank-to-pipe fuel line, but then it will start then die after a couple seconds. I think the problem is that gas isn't getting sucked out of the tank at all. I've checked the manifold screws, which were a little loose, so I put thread lock on them and tightened 'em up. I checked all the fuel lines to make sure they are connected to the tank, pipe, and carb well. I checked to make sure my fuel filter wasn't dirty. I looked at the L-coupler (it's a peice of crap, but the hobby shop I went to didn't have the exact manifold I want, so I had to use the stock coupler) very well for cracks. I can't think of ANYTHING that could be making it not suck up gas, and it's making me mad. HELP![sm=confused.gif]
Old 05-30-2004 | 07:56 PM
jkdv8's Avatar
How is the engine. Does it still have decent compression.
Old 05-30-2004 | 07:57 PM
Slacker's Avatar
It's a BRAND NEW engine. I just got done breaking it in the last time I drove it.
Old 05-30-2004 | 08:29 PM
hey slacker..i had the same proble last weekend and found a small crack around fill neck of my fuel tank...it looked like it was just a scratch but it was a crack...look the tank over and see if it's not cracked..hope it helps you.
Old 05-30-2004 | 08:34 PM
Slacker's Avatar
That may be it, 'cause I've pretty much ALWAYS had a problem with the truck priming. It's only worked properly when I first got it and maybe a couple months afterward.
Old 05-30-2004 | 08:35 PM
you might also check the cap seal too
Old 05-30-2004 | 08:54 PM
Slacker's Avatar
Yeah, I've already replaced that before (like, half a year ago) and it didn't help too much.
Old 05-30-2004 | 09:45 PM
i think the problem is that your fuel filter inside your tank is cloggled. just go to your lhs and get a new filter
Old 05-30-2004 | 09:47 PM
Slacker's Avatar
C'MON PEOPLE! I have a NITRO RUSTLER! There is no fuel filter in the tank, and, jkdv8, there is no primer bulb (PM message)! Work with me here.
Old 05-30-2004 | 09:49 PM
take the tubes off fill em up with water and chec and see f there leaking
Old 05-30-2004 | 10:03 PM
Slacker's Avatar
I'll try right now.
Old 05-30-2004 | 10:10 PM
Slacker's Avatar
Nope, no leaks in the fuel lines. Next test.
Old 05-31-2004 | 11:27 AM
Slacker's Avatar
I fiound out what was wrong with the truck. I was blowing through the tank-to-pipe line to prime itand I noticed some gas bobbling out of the place where the carb goes into the engine. How do I fix this leak?
Old 06-01-2004 | 09:58 AM
madblunted's Avatar
first try tightening it, then if that dont work take the carb out, check the o rings you may need to replaced them.
Old 06-01-2004 | 11:00 AM
Slacker's Avatar
I switched the seal out with the one from my old TRX Pro 15 carb and it fixed it. Now it primes REALLY well (so good that I keep flooding it), and now I just have to work on the tuning and getting used to tuning again, since I haven't driven my truck in about 5 months or so.
Old 06-01-2004 | 04:04 PM
madblunted's Avatar
Nice, good luck w/ the tuning.
Old 06-01-2004 | 09:31 PM
glad to here we all helped again...lol[sm=lol.gif]...glad you found it and got it fixed...let the bashing begin....
P.S. thanks for letting us know what else to look for in that situation..
Old 06-03-2004 | 09:41 AM
yeah good luck with it
Old 06-07-2004 | 10:35 PM
Slacker's Avatar
Weel, of course as soon as I get one problem I run into another problem or two. [link=http://www.rcuniverse.com/forum/Stock_or_Pro_Ball_Diff%3F/m_1882572/tm.htm]Click here[/link] to go to my new post about my new problems (this one would get too long and off topic if I just said everything under this post).
